Just ran a test of my N97 NAM with the FM transmitter.
I had tried in my truck to receive the signal and was unsuccessful, so I ran a test using a clock/radio.
It appears that the range is not 6 feet, but more like 6 inches. And you'd better be real close to the antenna side of the radio.
Anyone else with observations?
http://europe.nokia.com/get-support-and-software/fm-transmission
I've given it a go on my mini hi-fi at home, but it's connected to the aerial on the top of the flats so it didn't pick up the N97 very well. Thankfully I'm on the top floor so at least I heard *something*.
Yeah, six inches sounsd about right. Get an awful lot of buzz and static without. Poor FM Transmitter.
I tried my UK spec phone in the car this weeked, the aerial is located above the rear windows so there was some distance between it and the N97. I found the transmision from the N97 seems very directional depending on how it was held resulted in anything from no signal all the way to a clear audio.
Also if you equipment can recived RDS signals the N97 once tuned in displays as "NOKIA" on my radios display.
Can the FM Transmitter work along side Loudspeaker mode?
That is, can I take a call, listening to the caller over FM Radio, and speaking back to then over Loudspeaker mode wothout a feedback loop kicking in?
Is FM Transmitter+Loudspeaker combo a viable Car Kit replacement?
Thanks.
Tested this for the first time today and was pleasantly surprised. Aerial for the car stereo is just above the front windscreen in the centre (i.e. very close to the phone). Reception was absolutely crystal clear. Looks like I'm the lucky one judging by everyone elses comments. I did wonder whether it would be worth using because the one built into my TomTom is useless, but it looks like I can go ahead and stick some music on my N97 after all.
i think its shocking you have to have it close to the radios antenna otherwise the sound is crap. Utter uselessness if you ask me, i'll be connecting with a cable in future if possible.
just remember, you have to place the phone near the ANTENNA and not the radio head unit necessarily. there were a bunch of posts on howardforums from people saying it doesnt work when they put the phone up to their radio head unit. sure, that MIGHT work sometimes, but the phone really needs to be placed near the arial antenna.
on my car the antenna is in the rear windshield. not the easiest place for me😮
n97mann wrote:i think its shocking you have to have it close to the radios antenna otherwise the sound is crap. Utter uselessness if you ask me, i'll be connecting with a cable in future if possible.
I guess this is for 2 reasons.
- battery life
- you don't want to be transmitting a signal so strong you can interfere with anything else (like someone else's radio)
celios wrote:I guess this is for 2 reasons.- battery life
you have to remember that it all depends on what frequency you're using. if your using a frequency that is near a radio station frequency, it won't be very good.
i've found that 107.90 works fine where i live (here ish).
Tested in my BMW M3 and BMW X5...
totally useless.
FM Transmitter is a NON feature IMHO.
Total waste of space. Unless they can change the HW with a firmware upgrade to boost output (which I don't think they can)... chalk this up to "lame execution".
P
I think I'm one of the lucky ones as far as the N97 goes(so far). Only one minor contacts list issue which was solved with a soft reset. I have been using the FM transmitter in the car without any problems, always making sure i use a frequency as far from anything else. My aierial is a thin black stripe down the middle of the windscreen and the phone sits of the dashboard just below it, could be why I'm getting the good results, but I'm happy with good.
I only use mine in my work car, works flawlessly, can't fault it.
You must place it near the antenna, not the radio unit. You guys sure you're doing this?
RogerPodacter wrote:You must place it near the antenna, not the radio unit. You guys sure you're doing this?
My car antenna sits on the right hand side of the car, pretty close to the windscreen, but the car is a left hand drive, so its all the way the other side of the car! Tried the FM Transmitter at the weekend and tried it on the default frequency 90.00 but this was close to another radio station.
As I was in heavy traffic , I didn�t really get the chance to try a different frequency, but found that if I moved it closer to the antenna, it did pick the music from my phone, but not very clearly. Either it needs to be even closer to the antenna, or another frequency would work better?
The specified range of the transmitter should allow you to have it within a "reasonable" range of the antenna. It's not much use if you have to leave it in the back of the car to work. Yes, you could setup a playlist BUT the battery would soon be dead without being plugged in.
Just to add my dissatisfaction re FM Transmitter.
I tried it on my dab radio at work & it wasn't until I touched the ariel with the phone that I got anything 😞
Since I started this thread here is my follow-up evaluation:
You REALLY, REALLY need to experiment with "empty" frequencies to find one that will work.
When I first tried FM transmitting with my N97 it was with a clock radio and the N97 being chock-a-block to the back of the unit. Quality was poor but I was at the low end of the FM spectrum.
In my truck I experimented until a found a "wider" empty spot at the high end of the spectrum and could leave my N97 about 18" from the radio dash interface. It worked just fine until I drove past some power lines which were putting out a lot of interference. It just got blanked.
The FM feature then is something that needs a lot of trial-and-error before you can find a good frequency band, but then there are no guarantees.
I have an ariel at the back of the my car, so this FM transmitter is useless.... why did Nokia even put this as a feature, is it only for the fortunate few who have their arials at the front.. not good enough Nokia, really dissapointing
My ariel is also at the back of the roof of my car. The FM transmitter works perfectly over a distance of about 2m, no cracks, no noise. But I had to try some frequencies until I got it to work.
When I first tried it over the low end frequencies, the reception was poor, crackly, sound quality not too good and had to hold it very close to the car ariel � (car is left hand drive, ariel is on the right hand side )
So after a disappointing first attempt, I tried with other frequencies and got a much better reception and better sound quality.
BUT, this was literally all experimentation. The head unit in the car has an auxiliary jack plug, so can connect any other device direct to the head unit, that has a jack plug, and this is a way better sound quality. Could play the iPod through this and any other phone with standard jack plug, so this is still the preferred option to me, quick, simple, easy to use, no messing with frequencies etc, and a better sound.
I agree. If you can't make a connection using aux, you should then move to the FM transmitter.
