N95 8G problems
8 replies · 5,863 views · Started 23 June 2009
Hi, I am not sure whether anyone of you face these problems. Please advice me the solutions if you know how to solve it.
1. I can't transfer file via bluetooth from another phone. The error message is write failed. I can send out files to other phone though.
2. I installed Nokia PC Suite on my Win Vista. I try to add the the phone. I manage to pair it, but then receive this error: Aunthetication Failed.
3. I can't locate my wife settings. From the user manual, i should go to Menu-->Tools-->WLAN Wiz. But i can't see WLAN Wiz.
If you know any solution to any of the problems above, do let me know. Thanks.
air_salak wrote:Hi, I am not sure whether anyone of you face these problems. Please advice me the solutions if you know how to solve it.
BIG problems I have:
The browser opens quickly, but when I start clicking the links in the website, it will hung there, and message "no remote gateway".
1. I tried to close the browser, it would freeze.
2. I tried to search the wireless-lan again, it freezes.
3. I reset it several times, same thing.
4. I re-install update, no luck.
5. I reset without restore, same thing happened.
Have not set up email yet. The way it goes I am about to sell it and try my luck somewhere else.
fz75 wrote:BIG problems I have:
never mind. reinstalled again, fresh start eorked.
jApi NL wrote:@air_salak . How long do you use the phone , and since when do you have this problem ? It might be an corupted file . In case of a corrupted file , you can do a reset or a fresh firmware installation .
About resetting the phone , see this thread : http://www.allaboutsymbian.com/forum//forum/thread/81021/
Remember always make a Backup , to save your data .
😊 Reagrds jApi NL
Problem cam back again after I re-install RDM plus and worldmate.
The browser will start a lot quicker than b4, but as I went out of the range of the wifi, then come back again, the browser will freeze and cause the phone to freeze as well. Don't know if everyone has the same problem?
Anyway, now I am removing most everything using application manager and re-install everything again. hopefully the browser issue will be resolved.
It looks like you are using to many Web - served Applications at the same time ? If so : open only when needed and close right after .
😊 Regards jApi NL
jApi NL wrote:It looks like you are using to many Web - served Applications at the same time ? If so : open only when needed and close right after .
😊 Regards jApi NL
Unbelievable! Many re-installation and the problem persist!l
Before the latest upgrade thei week, I was bale to open max. 5 windows from the browser, in the same time ran other web-based programs, as well as accessing my email account ion the same time.
Meanwhile, the power consumption increased dramatically! Only last 50% of how it used to be now!!
Now this update just complete crap the machine out! Is there anyway to restore the s60 back to what it was with the last firmware. I read somewhere that is is not possible...😡
If Nokia is listening, [SIZE="6"]the latest firmware available V31.2.008 completely stinks!![/SIZE] for every one out there, I strongly advise [SIZE="6"]DO NOT UPGRADE![/SIZE]
having same issue, i upgraded the system software as soon i got the phone, never knew what N95 's wifi mangement was like bfeore 😞
let me know if there is a fix.
