I just found out from Sony-Ericsson that Voice Command or Voice Dialling is not supported for SBH-30 Bluetooth with P800.
Why or How then ?
SBH-30 Bluetooth
Not true.... I've been using my HBH-30 for the longest time with my T68 and now my P800.. No difference.. I tap on the button and the phone beeps and I speak the contact name into the headset and that's it.. I had the HBH-15 before that now I got the HBH-60 as well. You just can't use the magic word with the HBH-30, but I'm testing it with my HBH-60 which I was told supposedly supports that feature...
[quote="Anonymous"]Not true.... I've been using my HBH-30 for the longest time with my T68 and now my P800.. No difference.. I tap on the button and the phone beeps and I speak the contact name into the headset and that's it.. I had the HBH-15 before that now I got the HBH-60 as well. You just can't use the magic word with the HBH-30, but I'm testing it with my HBH-60 which I was told supposedly supports that feature...[/quote]
But today at the Sony-Ericsson service center, even the technician tried so many times, it did not work even once. But from the handset, it always works with or without magic word.
The question everyone is asking, do you record the voice command with the headset or handset. I tried to record with headset, does not work or I don't how to do it. Pls help.
Apparently the magic word feature is supposed to work with a car kit. However, just voice commands are done through the phone. Now that I've been using my HBH-60 for a while the features are not any different from the HBH-30. The comfort and clarity is deffinately worth it in my opinion.
I still cannot voice dial from HBH-30.
Error 'no match found.'
It works with the handset but not the headset.
The manual says, if you have problem with voice dialing from HBH-30, try recording from headset.
Exactly how to do this ? it does not record from headset ? Are there any controls or settings ?
Can anyone help.
