Disabling shutter sound in 6220
2 replies · 8,311 views · Started 24 June 2009
Hi guys, I've been using my new Nokia 6220 for a couple of weeks and I'm generally very happy with it (except for the fact that it needs charging quite often, but you can't have it all :tongue: ) , but I have one question.
How can you disable the shutter sound the camera makes in 6220?
I've tried changing to the quiet profiles but the sound always remains. I find it really annoying, and I'd like to deactivate it. Is it possible?
Thanks for your help! :icon14:
I don't exactly know for 6220 . For my Phone S60 v3 FP1 : Open Camera > Options > Settings > Camera Sounds/Tones : there is four items . Item 4 is the weakest sound .
The Camera Sounds are located in Z: > System > Sounds .
You can install a decent third party Filemanager for free like :
--X-Plore | Y-Browser
http://www.lonelycatgames.com/?app=xplore
http://www.drjukka.com/YBrowser.html
to be able to find these files .
BTW : I didn't try to delete them , since I like the use of sounds as a confirmation of picture capture ....
😊 Regards jApi NL
