Problem with Tab menus in call log and Bluetooth menu
2 replies · 5,793 views · Started 24 June 2009
I used JAF to change the product code on this network branded phone, then installed the Euro_1 RED v21 firmware.
I would consider myself a knowledgable user of all things Symbian. But this has me stumped
Basically, if I press the green button from stand-by I am presented with a list of dialled contacts & nos. But I can not switch left to view received or missed calls. The icons are there, but there is no way I can switch over.
Similarly, the Bluetooth menu is not what It should be. I can switch on the bluetooth, but can not switch tabs to connect devices and rename, authorise etc.
Am I missing something, or have I made a botch of it all?
P.S. When I did the FW upgrade, the phone became totally unresponsive, & it took me a while to cop on to the GREEN + RED + CAMERA button press. THis did seem to sort that out
this works fine for me. open the call log with the green button, and then at the top there are 3 tabs. i press each tab and it brings me to missed, received, or dialed numbers. tabs work fine for me in all of the OS menus. have you tried this? you have to touch each tab with your finger heheh. :icon14:
RogerPodacter, I tried everything, including actually touching the icons.
I actually cracked it though(some one else did).
Turns out it's to do with the theme. I had been using Ovi Blue so when I reverted to the standard Sound Waves theme, I can "touch" the tabs and switch between menus.
Happy out now, but it's gonna be tougher finding compatible themes now!
