Anyone have any idea whether there is such a program?
Looking for an FTP Client for the Omnia HD
This is the firsthit in google for ftp symbian. I used it on a 3d ed phone, will prolly work in 5th.
If there are problems with input, use VirtualKeyboard.
Thanks Jules!
I found that program but not the link you sent that allowed me to download it. I went to the software website and they text it to you and the install never worked correctly.
I am also testing Moby Explorer right now and it is moderately useful. I am going to try your suggestion now! Thanks again.
Greg
Written for 3rd edition but I just installed it on my N97 .. it works fine .. so in theory it should work with your omnia ..
http://www.box.net/shared/udng2o0ss7 should get it for you.
Oh best thing .. its Freeware .. so Kudos to SIC! Software GMBH and their programmers.
http://sic-software.com/modules.php?name=Content&pa=showpage&pid=58&sic=SIC+FTP+Client
SIC seems to be the one I am going to go with. I have one ftp site that for some reason closes when a file download completes and when I look the file hasn't come across correctly. Another site works perfectly. I have come to the conclusion that the software works perfectly and there is something different about the ftp site. Ah, oh well...I'll figure it out!
Thanks again!
