I was installing .sis applications on my N79 just fine but then suddenly it just refuse to installing any sort of .sis files - what happens is that i will choose to install a .sis file, it will start and continue into the disclaimer n etc, but when it actually get to the installation part, it will just exit itself and disappear without any error msgs.
Please Help, THX in advance
P.S. the application I installed last before this problem was Sensible Sudoku Cracked, where I had to alter my date and time in order to install. I don't know if this helps in finding the solution.
Did you check : Menu > Installations > App. Manager > Options > Settings > 1. All 2. Off . And of course : Set Clock back to the right Time ? Maybe the hacked app. is corrupted . In such case : de-install the App and give it a new try !
Otherwise you have to go through the Reset workaround , which can take about one hour . See this thread : http://www.allaboutsymbian.com/forum//forum/thread/81021/
😊 Regards jApi NL
Wow thx for the fast reply, yea I've tried all your suggestions already expect of course the format.
Im wondering if there is some kind of error log file, lol I really do not want to format - will be the last thing done.
I actually found this post,
http://myghimh.blogspot.com/2009/03/unable-to-install-sis-files.html?showComment=1245938072268#c1013190894267220540
seems like it might work, although I don't know how to access the /sys/bin .exe files yet
I don't know the answer to your question , but I think he uses the PC for this (I don't have one) . But with decent software used , I think this problem occurs also when the Phone runs out of memory : C: and RAM . Here is a thread how to clean and manage memory on your phone - it's about 5800XM , but works also for S60 v 3 : http://www.allaboutsymbian.com/forum//forum/thread/84082/&highlight=Save+memory
BTW : JbakTaskman is a nice application manager that also monitors Memory : C: , RAM and E:
😊 Regards jApi NL
SOLVED - yup thx 4 ur help
just set ur phone to mass storage (not pc suite) when plugged into your pc, and u can view all the files in /sys/bin via pc
once you made a back up of all files inside /sys/bin, then organize by date modified, and start deleting .exe files from newest to oldest
for me, after deleting sudoku (most recent installed app), the phone worked perfectly fine
