When i try to connect with tipicme it connects 80% and then it says 401unauthorized, why??? Can anyone help me?
Tipicme
Have you registered on the Tipic web site, if not that may be the problem
Bob
Whenever I try to connect it says Connection failed check your GPRS account in your phone. I've tried changing the Network connection to Allowed, but it still doesn't work.
In the console part it says: java.io.IOException: Status = -28
My WebViewer won't connect to the intornet either. What's wrong with my phone!??!?!?
[quote="littlecharva"]My WebViewer won't connect to the intornet either. What's wrong with my phone!??!?!?[/quote]
You sure you have Internet GPRS connection, not WAP GPRS?
Pretty sure. My email works, so that should mean it's internet right?
[quote="littlecharva"]Whenever I try to connect it says Connection failed check your GPRS account in your phone. I've tried changing the Network connection to Allowed, but it still doesn't work.
I have the same problem and i'm on Vodafone Live... so yes, GPRS is working... and i have registered in the tipic.com site....... someone PLEASE help
Contact your carrier, you may be on a GPRS for WAP only access, this i know prevents access to email over GPRS, you may need full Internet over GPRS for it to work.
Bob
In your GPRS settings, check that Internet GPRS has it's IP set to 0.0.0.0
this happens to me sometimes but if i just leave it to carry on, itll eventually connect but i have noticed it only happens to me in the morning,
Problem in getting register myself with yahoo's. ICQ and MSN are alright
I cant Install tipicme on nokia 7650.
When i Install Tipic on mi Nokia 7650 it sais that it has been installed, but it dony appears in the Java applications Menu on the phone.
I have tried to install several times and it never installs.
Can you help me?
Thanks so much
401 - check your username and password.
If you JID (Jabber ID) is:
[email protected]
your username must be in the form:
xyz
Gino
A Comparison between JustYak (www.justyak.com) and TipicME (www.tipic.com)
Have just download Tipic IM ver 1.2 beta on 7650 and tested it. I think
tipicME features like register new user, add/delete buddy, set icq,yahoo, etc all need
to be done by PC client. I even cannot exit the app. JustYak done everything on the phone , much better approach.
It is currently size is around 90Kbytes, much bigger than JustYak 65Kb, waste of precious memory.
Agree. JustYak connection is always very stable. Couldn't bear with TipicME. Anyway, my only vice is chatting so the JustYak chatrooms implementation have my full support :agrue:
Hmmm - unless I'm missing something here....
Why use ANY of these when you can use IM+ and connect direct to the MSN & ICQ servers themselves and NOT go thru and PAY per message a 3rd party proxy?
I use IM+ and find it VERY stable, fast, reliable AND I don't pay any other charges exept for GPRS.
Are there some kind of SUPER benefits of using these others that makes it worth paying another company to pass on your messages??
Best 😊
Will
[quote="scarborough"]A Comparison between JustYak (www.justyak.com) and TipicME (www.tipic.com)
It is currently size is around 90Kbytes, much bigger than JustYak 65Kb, waste of precious memory.[/quote]
All the feature you talk about are available in TipicME. You can add/delete/edit buddy, setup icq, msn etc. Did you tried it before talk? 😉
Also, do you noticed the big red button in the menu? It allow you to return to the main menu, and so leave the program. The bigger size was wasted for the graphics.
@willbrady: you don't pay nothing else gprs transfer to use TipicME...
Regards,
Gino
mhhh... strange...
@scarborough, chatterbox:
look at:
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?p=70344#70344
scarborough you made the same post in even topics. And chatterbox post a message after you. Are you in touch with the people who made JustYak? Are you the same person?
scarborough have 13 post, every regarding comparing JustYak and TipicME: http://www.allaboutsymbian.com/phpBB2/search.php?search_author=scarborough
I'm the developer of TipicME, but I don't go in every forum telling "TipicME is good, JustYak is poor". I'm here to make support, to ear suggestion, to watch what is working and what not, not to tell how is ugly JustYak.
Please, respect the work of other people.
Now, I will report your post to the admins; probably, the moderators will discover scarborough and chatterbox use the same IP...
Regards,
Gino
@ginomi
Oh ok - sure I read that you pay per message.
My mistake - I'm sorry, wonder where I read that then?
Probably got confused when flicking thru and reading the writups on all these 3 products.
I may just go and give it another look then 😉
Won't even bother with JustYak - blatant advertising, abusing the good people on the forum has put me off straight away.
Why not just say - Hi I'm from JustYak, come check out our new program?
Thats what other Softies do and I respect that - none of this cloak a dagger approch making out to be a forum user who just 'stumbled' accross this great new program!
Best 😊
Will
Looks like need to pay some bucks upfront.... do u have a cracked copy (hope you did not developed IM+ or my ass is going to get some real serious kicks again!) 😃
Seriously, does it runs well on Siemens S57. Also do they have chatrooms to chat with those faceless sexy teenage girls?
It was me who just posted. Sorry I am new here and did not realised that a guest could post a message so I accidentally posted that one without login. That brings about a question - how is the poor moderator going to scan all these IPs??
You can get a demo version from their website.
Gives you a couple of messages per connection and enough features turned on to let play and decide to buy it.
Best
Will
@willbrady: sorry, I did not want to be bad with you 😃
@chatterbox: your IP probably don't will be the same of scarborough, but that mean nothing, cause I can have different IP using the pc at home, at office, the pc of my girl, my phone... :evil:
So, this don't prove you and scarborough are the same;
Well, do you have a S57 phone? An ASIAN phone? strange, the company who made justyake come from singapore...
Domain: JUSTYAK.COM
Registrant/Owner: 000-CH07955
LineFusion Pte Ltd
50 Bukit Batok Street 23
#06-06 MidView Building
Singapore Singapore, 659578
SG
Please, tell us the truth, it's better for you and for your company...
Gino
Ohhh
A softie fight
Go on Ginomi go beat em up! 😉
:agrue:
😛opcorn:
willbrady, we make a lot of work to develope and support TipicME. It's a free software, but we have a lot of user -> a lot of bandwidth -> a lot of server usage -> a lot of money spent.
By the way, everybody can have personal opinion about a sw, but I can't allow other people try to denigrate our work in THIS way. Untill today we are working a lot without make money, but also without create conflit with other competitors, like IM+. I've every time told I'm the developer of TipicME and VNCviewer, I've every time used my name to firm my posts; I don't like people who use muliple identities and false names to advertise and spam. This is my point of view, no fight, of course!! 😃
Gino
Hey I totally agree with you my friend 😊
There is nothing wrong with critasism, it makes a better product, but I agree with you, this just looks like another softie saying your product is bad just to sell more of his own. That's not fair on you!
We must respect the softies as they make our phone great!
That's why I NEVER use cracked software and just use Demo's to evaluate the BUY the full product if I use it.
I personally don't use your program, but respect your position and was first to appologise when made a wrong assesment of your program.
Have a good day my friend 😊
Best
Will
This is getting real fun. So, if the kind moderator can prove that my IP is from Indonesia and not from Singapore then I am not Scarborough and all should apologise to me? 😃
I do respect the money & time spent on s/w development and I am not using any cracked s/w either. May be my English is so bad that I miss-interpreted Will's first message. I thought Will suggested that IM+ was free, so I was surprised to find out it is not, later. I was pulling Will's leg. But I appreciate Will's advice on the demo s/w.
I am an end user and I want to choose a product that suits me. I don't give a f about who run which f companies. If I have to pay for a good product or service, that's fine with me.
If I spend my precious time (well...) to give my opinion about your product, please thank me and improve on it. If your product is good, just stay cool my friend. Nobody can run you down.
I don't necessary like blantant (depending on your standard..) advertising as posted by poor Scarborogh either, but I am educated enough to know that you got to try out these products to see which ones works & suits you and not just read about the marketing words.
So, please no more f%#& Justyak, Tipicme, or IM+.
Can someone please give an opinion on Siemens S57, now? May be some Asian friends, if this phone is really only available in Asia.
You are using a cracked version of IM+? Ha!
Pay a bit for better service, don;t believe in free things
Ok ok, I am the CEO of justyak, if dat make you feel better 😃
Ok ok ok, I am chatterbox, you must be very happy by now 😃 😃
or may be I am the CEO of IM+, Opera, Trillian.....? 😮
I am just myself and not any of the above
@scarborough: I don't wont to comment again your words. I've just exposed to other people in this forum my opinion (and the official Tipic position) about you and your spam messages.
If you don't like to talk openly please don't reply and leave this discussion.
Regards,
Gino Micacchi
Wireless Engineer
Tipic Inc.
