I use Handy Weather (among other 'Handy' programmes). Since doing a hard reset and complete reinstall yesterday, I can't get Handy Weather Screensaver to work. I remember that this happened before and that I found out it is a known bug, and that there is a work-round. But of course I can't for the life of me remember what that was! :frown: Can anyone please help?
Cheers
Aidan
Handy Weather Screensaver issue
Abell wrote:I use Handy Weather (among other 'Handy' programmes). Since doing a hard reset and complete reinstall yesterday, I can't get Handy Weather Screensaver to work. I remember that this happened before and that I found out it is a known bug, and that there is a work-round. But of course I can't for the life of me remember what that was! :frown: Can anyone please help?
Cheers
Aidan
As always if all else fails consult the manual! This states re-install Handy weather, restart phone and go to menu Themes. Under powersaver select weather. Hope this helps.
Thanks Kcfischer. I bought the programme in the bundled "Handy Tools pro" online which didn't come with any instructions - not so much as a pdf! However, I've got it working now, I think it was the re-boot that did it.
Cheers,
Aidan
You can for certain applications online the pdf manuals downloaded.
Kim
I have Handy Weather S60 which I never used. Now, when I am ready to use it I realized that I can't find installation CD supplied with the phone. Can anyone tell me where I can find this software. Thanks!
here you go.
http://www.allaboutsymbian.com/software/item/Handy_Weather_for_S60_1-Year_Subscription.php
the company name is epocware.
i hope you still have the registration code.
is walid for 1 year.
in case you lost it they will help you trough help page.
http://www.epocware.com/company/E-Care.html
regards,
D
TheSpecialBoy wrote:here you go.http://www.allaboutsymbian.com/software/item/Handy_Weather_for_S60_1-Year_Subscription.php
http://www.epocware.com/company/E-Care.htmlregards,
D
Thank you very much for help. I did not loose the registration code.
