When I want to turn on wifi, I go to the WLAN Wizard, find my Broadband connection and click on it. It then ask me to "Start web browsing". Why ? Why can't I just turn it on with browsing the web ? I may just want to update my emails on my phone.
Did I do it right ?
When I turn on my WLAN and found the WIFI,it will display the same thing�Would you like to browser the Web�?I guess every mobile will do this.
Why don't you just open the browser and choose the wifi as th access point?
Cause I'm not going to open the browser. I want to check my email. Seems to me the only way to start a Wifi connection is to select the AP and open the browser ! Weird.
mrochester wrote:Why don't you just open the browser and choose the wifi as th access point?
How are your settings in Web browser ? Set Web > Options > Settings > General > Access Point to : Always Ask .
😊 Regards jApi NL
You referring to my post ? I'm not using the browser at all. But if I were to connect to WIFI (WLAN Wizard), it will give me 3 options:
1. Start web Browsing
2. Refresh
3. Details
Why it does not give me an option to just connect ? I only want to read emails and not browse the web.
jApi NL wrote:How are your settings in Web browser ? Set Web > Options > Settings > General > Access Point to : Always Ask .😊 Regards jApi NL
I think the option connecting to Wifi and reading Email , without browsing the internet (Web) , would be great but not possible . Even in Messaging , setting your Email account , you will have to set an Internetadress , using the Web (by default) to pick up the new messages .
Using the Webbrowser , set to "Always Ask" , to read your Email , gives the opportunity to choose between Wifi and 3G / GPRS .
😊 Regards jApi NL
csc12345678 wrote:You referring to my post ? I'm not using the browser at all. But if I were to connect to WIFI (WLAN Wizard), it will give me 3 options:1. Start web Browsing
2. Refresh
3. Details
Why don't you select wifi as the access point for emails then?
I did. But if I don't first go to WLAN Wizard to connect to the internet via Wifi, the email client cannot connect.
mrochester wrote:Why don't you select wifi as the access point for emails then?
Scroll via Options in your Email client to : Connection Settings IN/OUT and change Access Point in use to : your Wifi
😊 Regards jApi NL
Already set to wifi. I get "Unable to connect. WLAN network not found."
jApi NL wrote:Scroll via Options in your Email client to : Connection Settings IN/OUT and change Access Point in use to : your Wifi😊 Regards jApi NL
Are you be able to browse the internet using Wifi ? Or do you get the same "cannot connect" message ?
😊 Regards jApi NL
I can access Wifi and Internet..no problem. Just that when I want to read email, I have to start the browser first...
jApi NL wrote:Are you be able to browse the internet using Wifi ? Or do you get the same "cannot connect" message ?😊 Regards jApi NL
Is your wireless access point hidden (set so other people can't find it)? My old N95 used to have problems finding hidden wireless networks..
BUt I think my point is when I use WLAN, why isn't there an option to say CONNECT ?
It has refresh and web browsing. It also has disconnect from WLAN but it does not have CONNECT.
Probably to avoid battery drain for a useless connection . It makes sense to establish a connection , when an application like email needs it . Read the forum about battery drain in N97 and Samsung 8910i , where multiple Apps need internetconnection .
Hope you found a solution for the email connection issue .
😊 Regards jApi NL
