hi..
im syafiq from malaysia..
my problem is..
i cant install software that i download from the internet..
it said,"certificate error" & " can install protect software from untrust supplier"..
help me anyone????
im begging all of you....:frown:
just provide me the sollution for my problem..
how to sign unsign software??help me????
syafiq-chan wrote:hi..
my problem is..
help me anyone????
Point your browser at www.opda.net.cn then register and apply for a certficate matching your handset's IMEI number. All the instructions are available there.
Most unsigned apps are hacked / cracked apps, and may contain a virus. Be careful installing these apps, even when you have an OPDA certificate to do so!
Did you set : Menu > Installations > App. Manager > Options > Settings > to : 1. All , 2. Off ? And try again !
😊 Regards jApi NL
jApi NL wrote:Did you set : Menu > Installations > App. Manager > Options > Settings > to : 1. All , 2. Off ? And try again !😊 Regards jApi NL
It is allready the default setting in all phones.
he needs the sertificate to be able to install all unsigned programs
