Is PC Suite able to sync Chinese characters ? I'm getting corrupted characters and also keep having duplicates for those item. Thanks for your advice.
Sync Chinese characters in Calender, Task, Contacts
Hi csc12345678
Make Sure that your phone has got support for Chinese characters... If its a chinese variant, then it will usually should display the chinese characters else you will get junk characters 😞
Its always recommended to use same language on your PC, PC Suite and Phone so that everything works smoothly 😊
Let me elaborate. I can see the Chinese characters in the Phone. WHat I also see is that I have duplicate records in my Outlook. THe original with the Chinese character is still there plus duplicates where the Chinese characters become currupted.
Any idea why ?
cricfancy wrote:Hi csc12345678Make Sure that your phone has got support for Chinese characters... If its a chinese variant, then it will usually should display the chinese characters else you will get junk characters 😞
