I expect my new 7650 within a week and I have a few questions on forehand:
- What is the latest firmware version? I saw some posts about 4.29 and even about 4.46.
- Does any Dutch user know where to upgrade the firmware (if needed) in the area of Rotterdam and what it will cost?
- I am doubting about my BlueTooth USB thingie. Any experiences with the one from MSI or Sitecom?
- Any tips and tricks needed to know before installing PC Suite?
That's it for now. TIA for any response.
JW
Hi JeeWee
welcome - it seems that the f/w is 4.39. (If you search this forum, you will find what each new release brings). All the same, check nokia.com, support to find out your nearest NSC - they can tell you what they have and what cost if any there is (you will get what they have...)
about BT, dunno, don't use it.
I seem to be the only person who doesn't have problems with PC suite. I run f/w 3.16 and W2k. If you have XP, search the threads...
Best of luck Paul
hi!..
Just about Bluetooth..
i use it all the time...
not problem at all.. al work perfect... you just need to installed right..
Firmware i think that 4.39 it's the official last one...
cya!
