SMS problems
2 replies · 2,104 views · Started 15 April 2002
Help Please
My 9210 has started reboting when i try to send SMS messages, it fails to actually send the sms and totally resets itself User posted image
I cant send them from the front panel either, the thing wont actually let me into the write message option, it just puts me back to the main screen.
Help Please
Also, want to try re-setting the thing to factry defaults, any ideas how ?
Steve
try pressing shift + ctrl +"I" for few seconds during reboot (white screen)
or shift + ctrl +"F" --- warning this will format ur communicator, try saving ur data first.
hope this helps...
Well I gave in, i couldnt get it to work no matter what i did - nor could i format or wipe the internal card, kept cmplaining that files were open, and the ctrl-shift-F and many other combinations wouldnt work.
So i took it back to the shop, a nokia rep was there and he couldnt get it to send an SMS so i gave it back and got a new one - I love the Link, so helpfull.
Cant see what is different between this and the previous one but at least this one works User posted image
Steve
