Firmware updates for N96 (V.30.033) and N97 (V.11.0.21)
9 replies · 20,519 views · Started 01 July 2009
Hey guys I installed today the new update but I can see anything big new... I feel more velocity... but nothing else more in my N96... What do you know about this update??? After I installed it disabled my Nokia Share (I had to unistall it because I didn't work again) and the Email notifications of Nokia Messaging (easy to restore in settings)... And just when the phone restart is giving me and error/warning about the Theme I am using for my Main/Wait screen... I switched between other themes and style the same... I thought it was a problem with my custom theme (the Ovi blue theme)... but with the default happened the same... I switched to left aligned menu view and the warning dissapeared but now I can not see my emails notifications... I am think of make a hard restart to my phone... but I will wait to see your replies...
The only new I have noticed is the TV thing in the Apps folder... but here in Venezuela it doesn't find any station... a shame!
N96 (V.30.033) :con?
Whats your product code? I use Euro1 0543713 and I only have v20.050 available :con?
Edit: ah it seems the v30 upate is only available OTA at the moment, installing now 😊
I have updated OTA and have seen no major improvements or flaws if I get any probs with it I will do hard reset and see how it goes
Oh by the way using Euro 1 code on debranded Voda Handset
What I've noticed on my N96:
1. Generally feels a bit zippier
2. Slight improvement in battery life
3. Bug that showed "Location" of meetings rather than "Description" seems to have been fixed.
4. My iGo BT keyboard doesn't work any more.
deebr wrote:What I've noticed on my N96:
i have also noticed a slight improvement on the speed front but my alarm clock no longer works :con? is yours working ok?
deebr wrote:3. Bug that showed "Location" of meetings rather than "Description" seems to have been fixed.
Great that you noticed that! Thanks for report it!
Hi there.
I downloaded the latest 30.033 via the P.C on my N96's and everthing went smooth. Phones run quick and fast and all menus and apps open very fast.
Dare I say it, but even the battery seems to last longer, the only negative is that I had to re-install Mini Opera
Krijg bij nokia als bericht geen nieuwe update,
terwijl er toch een nieuwe is die ik ook hier niet kan vinden.
weet iemand raad
bij voorbaat dank.
Word on Twitter is that there is a new firmware for the N96: 30.101.
For EURO1 I can not update.
I understand that the update is for EURO2 and Turkish devices.
Still no change-log on the 30.033-version..?
