Does anybody know if "Displex Display Polish - Scratch Remover" is safe to use on my N97 screen...
Got some mild scratching on mine already (*sigh*) and it's really irritating me...
Cheers,
D
Cheers,
D
Attention: use only on non-coated surfaces and plastics; when used on mobile phones, treat only the transparent portions of the display lens. Not for use with touch screen displays.
The above was taken from the mobile fun website who retail Displex. I have had mixed results over the years with this product on non touch screen devices. I certainly wouldnt try it on my N97.......:frown: .
Hope this helps
Craig
hootie wrote:Attention: use only on non-coated surfaces and plastics; when used on mobile phones, treat only the transparent portions of the display lens. Not for use with touch screen displays.The above was taken from the mobile fun website who retail Displex. I have had mixed results over the years with this product on non touch screen devices. I certainly wouldnt try it on my N97.......:frown: .
Hope this helps
Craig
Dagnammit!
Any suggestions for light scratch removal on an N97 anybody?
D
davecozens wrote:Dagnammit!Any suggestions for light scratch removal on an N97 anybody?
D
the mighty power that is google says: toothpaste and elbow grease!
best thing to do is get a martin fields screen protector, once its on u wont see those tiny scratches and ul have protection in future
Are they again good or are they really bloody fiddly?
davecozens wrote:Are they again good or are they really bloody fiddly?
there very good, not to fiddly, and once its on u cant tell, there washable also, iv used them on every nokia iv had and not had any probs
