Newbie Question
12 replies · 1,996 views · Started 04 March 2003
yeah if you search then it will be, rather than askign stupid questions when the it has probably been answered a million times before, SEARCH
the search is not like yr used to with Google, but once you're inside the thread the words are highlighted, so you can quickly see if that's what you're looking for.
Bear in mind there are over 60 pages of threads on this forum alone. If you add on the support FAQ, loads more.
Check it out
Paul
RoosteR,
You were new once, go easy man.
Typetubo, the search is at the top of the screen, there is a great deal of information on all sorts of topics in the forum. Basically you will need an application such as Fexplorer or Handy File and send them via IR or BT.
Good Luck and welcome.
Bob 😃
hes been a member longer than me, and i sure as hell got a rarseing for asking dumb questions lol, sorry man didnt mean to get offencive
"yeah if you search then it will be, rather than askign stupid questions"
Hey ASSWIPE is it stupid to ask for help? your dork take it easy go pratice some sport...
"when the it has probably been answered a million times before, SEARCH"
So WHAT? one more time wont kill anyone...stop being so FU...ING lazy.
To the others...Thanks for all....
whilst i think RoosteR was a little bit harsh, it is true, there is a search option and many questions have been answered there already. i have been on the forum for only a few days and have already seen the same things repeated and it does get annoying.
On the other hand Typetubo you should have used your common sense and the fact that RoosteR was willing to point you the right way was more than he had to do and i would have been grateful for that, and certainly wouldn't have posted such an unfair 4 year old style reply aimed at the poor bloke when TBH your the lazy git for not bothering to search!
Searching is a good thing and will help, but again why not just tell him how to get his pictures first off. At the end of the day thats what we're here for. I feel the more I can help others the more I'll learn new things and be more confident in the things I already know.
The way I do it is to backup the phone to the Pc using the Suite, then in the Nokia folder on your harddrive (normally C😊 explore through there and you will find a backup of the videos you took, in a folder named Videos. From there just copy and paste to where ever you like and play them.
A file explorer program will do the same, using it just search it out using the saved name and send via what evers easier.
Hope it helps.
