Hi people,
Ive posted on a few other forums and sent an email off to nokia about this but i'd like to know if anyone has experienced this?
Turn the phone off, then on again.
When the widgets first load up itll ask you to connect to an access point (wap or wlan), tell it to connect to WLAN and let everything update once.
Now walk away til you cant detect the WLAN and try to get things to update, it wont come up asking to reconnect. They will just keep trying to connect to the WLAN over and over and over and over again even though it cant detect it in range...
Is this happening on other peoples phones? The above has happend with pretty much any widget (first on accuweather, then news.com.au widget)
This is the only issue im having with it not attempting or asking to select any other access point. Other than that the phone has been pretty much perfect.
All i want it to do is:
Connect to my work wireless lan when its in range at work
Connect to my home wireless lan when its in range at home
Everywhere else go back to the 3g connection
Its meant to be able to do this with the priority list but it seems to not use it?
I can get it to ask which access point to connect to by restarting the phone but i shouldnt have to restart it when it should work...
