Hi
I have installed a couple of themes on my innov8, but i just cant figure out how to remove them :con?
So does anyone know how to remove installed themes on the I8510?
- Alex
Hi
- Alex
I am Nokia user , S60 V 3 . So there might be slight differences , but generally the same . When you install a third party Filemanager you can find the location :
--X-Plore | Y-Browser
http://www.lonelycatgames.com/?app=xplore
http://www.drjukka.com/YBrowser.html
Using X-Plore you can de/activate system files . Y-Browser always shows system files . I installed themes only on MemoryCard . The files are in : E: > Resource > Skins . However just Codenumbers . On the Device Memory they are probably in : C: > Data > Resource , but I am not 100% sure of this . Could be also : C: > Resource .
When you installed the themes in the Device Memory , the easiest way to get rid of them is a Hard Reset . See this thread :
http://www.allaboutsymbian.com/forum//forum/thread/81021/
Hard Reset removes all your personal data from the device memory , so be sure to make a Backup !
When you installed the themes on MemoryCard , Hard Reset doesn't remove them . Formatting Card does remove ALL DATA .
So try to delete the themes , while using X-Plore or Y-Browser .
😊 Regards jApi NL
The files are in the - "E: > Resource > Skins . However just Codenumbers " as you mentioned.
I installed X-Plore it reminds allot of the already included File mgr. It has the same problem and cant find the installed files
I also tried Y-Browser, i can install it but cant find it, did read through the FAQ for the product and it seems it won�t work on some mobiles.
3d and last try i fine combed through the entire phone, and woila there it was the Tool i missed i had in my phone >.>.
Menu --> Tools --> App. mgr.
There you can remove anything you installed, including some of the shitty themes i installed haha.... O.o
But i really appreciate that you tried to help me jApi NL =) thank you
Regards Alex
EDIT: Appears that it can�t detect all the themes you have installed only a few of them.
So you & me both are right ! I knew about the App Mngr , but also that not all the Theme Files can be found there . That's why I gave this workaround . Anyway , when you did install the themes on Card , they are listed in E: > Resource > Skins !
Using X-Plore : Press Menu > Tools > Settings > Mark System (folders/files) and go back . Now you can find Resource etc.
A nice feature is also Hiding Folders/Files . Also Y-Browser does this .
BTW : themes by default , I don't know where these are listed , except somewhere in Z: (= firmware) .
😊 Regards jApi NL
BTW : X-Plore has also it's own file viewer
Good to know, i install all my themes directly in the phone memory as i have a couple of GB in it hehe.
"Using X-Plore : Press Menu > Tools > Settings > Mark System (folders/files) and go back . Now you can find Resource etc"
It appears i don�t get the same menu options as you have maybe because i downloaded the free version from their homepage...
I see this:
Menu --> Tools --> Configuration
Messaging
File associations
Program update
Device Info
Restart Device
About
I missed your answer in the Cyclone of the M97 Forum . Since I don't use the English - but yes! free - version : in this case , press Configuration , then a menu pops up : mark the fourth choice "Show system - Files/Folders . After marking go back to E: Resource etc .
Anyway , when you start to play with X-Plore , you will find many features : including its own mediaplayers , just open a foto file , etc
😊 Regards jApi NL
