How does MAPS work in N97?
4 replies · 2,552 views · Started 05 July 2009
I open the NOKIA MAP LOADER and downloaded my country map.
Then i opened MAPS in N97 and it doesnt connect to the satellite for some reason. I tried for 2 days now and its not connecting to satellite.
Is there something else i need to do?
And will this MAP show me turn by turn directions?
Thanks.
I don't know why it wouldn't be connecting to any satellites, as there could be many different reasons, but yes it does include a free 90 days trial for turn-by-turn navigation. After that, you have to pay for it, but you can continue to download maps for free and use the application for anything else for free.
If you are indoors you won't really stand a chance of getting a satellite fix. You need to be outdoors or in a car.
Also the "A" part of "A-GPS" (Assisted) uses your cellular carrier's tower information to get a rough first "fix". You need to let it use the network to get a fix quicker.
The 3 month "trial" period can give you turn-by-turn directions. I ran my N97 in a side-by-side trial with a Tom-Tom One over a 130 mile trip. Both performed within expected tolerances of each other. The N97 gave briefer instructions a little less often, but was timely and accurate with turns.
BTW...GPS with the display always-on really runs the battery down, so I'd suggest that in the car for a long trip you keep it on a charger.
with agps on i can get signal indoors in quite a quick time as well
agps will only use tiny amounts of data like a few kbs worth
if you can use it do it if not it will take a bit longer
maps , you pay for a liscence then get free map updates for most countrys
nokia website has a discussion group on it with many topics allready covered
here http://discussions.europe.nokia.com/discussions/board?board.id=navigation
there is also a maps product page here http://europe.nokia.com/find-products/nseries/demos-and-tips/gps-and-nokia-maps?tab=demosTips
Try this :
1) Go to locations > Positionsettings > Methods
Choose Assisted GPS + Integrated GPS + Network GPS
2) In the same menu, press back, after selecting and then choose Positionserver
Set automatic + Choose an acces point (your mobile data connection (NOT WIFI)). Type in server-address = supl.nokia.com
