I know that this is not problem, but it is a MINOR annoyance--so in the event that the Developers @ Nokia might be listening for the sake of IMPROVING the UI...
Since the typical application selection screen only has the D-key and sidebar scrubber scrolling (i.e. no "flicking" or kinetic scrolling to select), I for one would prefer to keep any required scrolling to a minimum to get to my desired application.
Folders are a great way to manage the icons as they get more numerous.
In Options-> Organize for Applications users can create folders and move applications into these folders to make the UI more Symbian in appearance and less iPhone-like.
Home screen shortcuts aside where you are limited to at most 8 short icons, folders are the way to manage those beyond your 8 favorites.
It follows then, that for screen efficiency, it would be nice to select the actual placement of the icon on the screen so that the most used ones are in the easiest-to-reach position.
HOWEVER...Nokia chose to include a FOLDER NAVIGATION icon in the upper leftmost position of the Organize display so that all icons are DISPLACED by one in a wraparound fashion from their final position.
Can't there be a better way to do this to be more WYSIWYG?
