Psiloc World Travel (N97 BUG)
1 replies · 4,085 views · Started 07 July 2009
I'd noticed this bug before but had blamed it on Accuweather.
Turns out the culprit is really Psiloc World Traveler.
If you run PWT and go through the settings and check Options->Settings->Weather on main screen (ENABLE) it will create a To-Do list item in the Calendar with the following typical parameters:
Title: 32 C Wind: 4 m/s
Due date: (today)
Priority: High
Description: 32 C Wind: 4 m/s
Most notable is that I had selected Farenheit as my temperature units in PWT, but it displays its main weather screen in Centigrade and m/s, though it does display the forecasted highs and lows in Farenheit.
I have tried the other features and times display correctly. I have not validated currency exchange rates, but they "look" about right.
This negative affect on another program is totally undesirable.
YET ANOTHER BUGGY PROGRAM THAT IS NOT QUITE READY FOR THE N97.
*** UPDATE...shortly after delving into this program I experienced a "rolling crash"...first the web browser lost its top and bottom right sidebar menu buttons. Literally they disappeared and the zone were no longer touch sensitive. Then the display went back to the home screen, went one-quarter intensity, then went totally white (full intensity) then little lines of different colors went across the display left-to-right and then the unit restarted.
I suspect the PWT program may have had something to do with it since it put junk into a home screen applet (see above).
I knew this was preinstalled on teh phone, but didn't look at it til the other day, and was quite pleased with it.
I haven't noticed anything peculiar with it effecting other applications, I have set as a shortcut from the home screen, but still use teh Accu Weather as teh main weather widget on Home Screen.
The currency exchanges work well, as do the time clocks, but was a bit disappointed to see the flight checker not fully enabled. As I'm doing a lot of lying in the next few weeks, though that would be rather nifty.
Anyone any idea when this will be ready?
