Facebook Widget Keeps Disappearing
4 replies · 2,574 views · Started 07 July 2009
The facebook homescreen widget keeps removing itself frrmo the homescreen and not being reinstalalble without manually reinstalling the facebook_n97.wgz file
I'm running v11 f/w
Anyone else having this issue - I've *#7370# about 3 times now, but that doesn't help and I'm getting a little bored of reinstallign stuff...
D
Hmmm... i have a feeling it's because they're isntalled to mass storage and I've plugged it in and used mass storage... speculative at this point... I'll keep an eye on it...
D
A note....if you are plugged into your computer via USB in Mass Storage mode, you lock out the N97 from accessing files on either E: (Mass Storage) or F: (Memory Card).
I found this out while trying to start the Maps application while plugged in. It complained about not accessing Mass Storage and then said that it was saving Maps to C:.
I checked aftward and my C: free memory went from 41.7 MB to 29.8 MB.
I think I may have to do some weeding and culling to get the memory back.
We really, really need a Knowledge Base type write-up on how to manage the memory on C: drive, beyond deleting apps and reinstalling them in Mass Memory.
I always connect my phone in PC Suite mode. I can access the Mass Storage and Memory card from the Nokia N97 icon in My Computer, once it installs the drivers.
But then I do have PC Suite installed on all the PCs I use... I wonder if that's the reason why.
In my head it always seems that data transfer is slower in pc suite mode than mass transfer. Don't know if that's true.
But since using mass transfer effectively kills any widgets installed on the homescreen that are installed to the mass memory, I might have to go that way...
