Keyboard shortcuts
3 replies · 5,393 views · Started 07 July 2009
Has anybody got a list of the keyboard shortcuts available in the N97?
As an example, I am looking for a shortcut to go straight to the first email in the several hundred in my inbox after I have scrolled down a few hundred to view one from a couple of weeks ago.
I haven't found anything and unless there are more options than mentioned in the user guide it would seem there aren't any proper keyboard shortcuts for power users. Hopefully I am wrong, or more will be added. It could be possible that an application could be created for listening to keypresses in order to enable shortcuts.
From the guide:
To enter several special characters in a row, press
twice.
To enter accented letters, for example �, press the sym
key and then the A key repeatedly until � is displayed.
To change the writing language, press and the sym
key.
If you were trying to put graphics in your post--they didn't take.
To enter accented letters...press-and-HOLD the Sym key while repeated pressing the letter.
This also begs the question...if you use a bluetooth keyboard, will you be able to enter Ctrl-key combinations, and if so, will the application(s) be able to handle them as expected (copy, cut, paste, etc)?
What I'd like to see are keyboard shortcuts for the web browser, like the ability to go back and forth through your history, stop a page from loading, or go straight to the bookmarks.
