News Buzz Widget
2 replies · 3,726 views · Started 08 July 2009
Ok, so downloaded this t'other day, installed fine, no problems, configured it ok, works fine....until I connect the phone to the laptop for mass storage.
After disconnecting, the widget simply disappears from the home screen. Have to go into edit contents, and add the widget and then it loads up fine.
Anyone else? Or is it something I said...
Happened to me too... I'd uninstalled facebook by mistake and when i reinstalled I did so to e:
Any widget installed on the e: drive will be removed if you connect in mass storage mode when it's active...
So either don't use mass storage, or widgets to c: I'm afraid...
D
