Hi!
I have a N95-1 and never got the chance to try 3G connectivity. Now, testing with a SIM that is known to have 3G enabled flat data transfer, I insert it in my phone and the signal goes to GSM. I then force it to UMTS under options and it sits there in "3G" with no bars on the signal and no connection at all. When I go back to GSM, it works OK.
Now that very same SIM (and even my original one), when plugged in a N85 next to my phone, works fine at 3G. So... the question is; is there something I'm missing here? Why doesn't it detect 3G signal in my phone?
This things are facts:
- I'm near a strong antenna (the other phone gets full signal)
- I've recently hard resetted my phone (I've done it several times since the last 3 years and it never worked with 3G)
- I'm using latest FW version (v31.0.0.17)
Anyway... I'd really appreciate any light you can shed in this! Thanks in advance for your time
