Can't upgrade my N95 to v.017 due to BB5 ADL Loader hang
0 replies · 2,673 views · Started 09 July 2009
Hello,
Again, coming back for some help from the group.
Yesterday I was required to update my firmware, from v.15 to v.17, so I put PC Suite working and downloading the 139MB files but prior to that, a newer version of PC Suite was downloaded to my PC.
Then I connect my N95 to my PC and automatically starts installing some 6 or 7 drivers, all related to either Nokia or N95.
When the last 15 minutes start and the phone starts to shut down and all the usual procedure of firmware updates, I get a message that states that PC Suite has "lost conectivity" with the phone due a problem with the BB5 ADL Loader, then it just hangs forever. Also recomends, disconect the battery and USB cable from the phone and re-start it....repeated many times and same result, just reaches the last 15 mins and hangs because of the conectivity looses.:con?
Lucky, the phone didn't loose any info and keeps working, but could'nt upgrade to v.017 so far.....
Any help available?, any one found and solved this issue?...
Thanks very much for the help and support.:frown:
