i just noticed that whenever i use flash the left handside of the photo is all whited out. Looks awful. Does anybody else have this problem.
If not, should i talk to nokia or expansys?
D
D
Try cleaning the lens. I had this problem (not as severe as you by the sounds of it) and I fixed it by cleaning the lens.
Tried that to no avail. I've just notice there appears to be a scratch between the led and the lens, bang in the middle. I assume this is being illuminated by the led and flooding the pic.
Nasty...
Question is, if something has got under the lens cover and scratched the lens within 2 weeks, is it a warranty covered issue?
D
Man I have the same problem!!! The left side of every picture i take in the dark is blurred with too much flash. Were you able to fix this problem?
Nope, not me nor 500+ other people...
See http://www.petitiononline.com/N97lens/petition.html and www.davecozens.com/n97/scratch.htm and http://www.nokiausers.net/forum/nokia-n97/29063-n97-camera-lens-scratched-post-your-photos-taken-your-n97-here.html
Don't expect Nokia or Expansys to acknowledge it as a recurrent issue though... neither of them have ever heard of it...
i signed the petition. were you able to get in replaced through nokia warranty?
i'm waiting for a replacement n97 as we speak...
There is a possible temp fix, on symbian freak, they suggest using a very very fine tip black marker and just draw a line down the side next to the lens, before the scratched lens, people were still getting this because the flash is recessed. I havent tried it yet cos i dont have a fine enough marker around, but will let you know if it helps when i do!
