Yesterday, i updated my 5800 to the latest firmware V 21.0.025. After that I went into Applications>App. Update. Two updates were available:
1. Mail For Exchange and
2. Adobe FlashLite 3.1
I started the update, both were downloaded, but while installing only Mail For Exchange was installed. Adobe FlashLite 3.1 update failed. The only error message i get is 1 Update Failed.
So any ideas how I can fix this......Where is the temp folder where these are stores, i may be able to delete the old download and download it again........
So can someone please help me :con? ?
hamzahsa wrote:Yesterday, i updated my 5800 to the latest firmware V 21.0.025. After that I went into Applications>App. Update. Two updates were available:
2. Adobe FlashLite 3.1I started the update, both were downloaded, but while installing only Mail For Exchange was installed. Adobe FlashLite 3.1 update failed. The only error message i get is 1 Update Failed.
Connect your phone using USB select Mass Device. Browse to /phone/Private/20019119/[20001a4a] and delete any *.sis
Go back to auto update that should re-update the two files that is bad.
I have the same problem. Run the steps above will solved it.
