Can any help me please, i'm new to all this. I've just installed Garmin XT to my nokia N95 8gb and it works a treat. The only problem i have is that i don't have the Postcode search option................
Is there somthing i need to do or download? Is this part of Garmin or is it part of the maps i need to download? I currently have the europe maps installed. please help as it's driving me nuts!!!!!
Garmin XT with Post Code search
dodgepot wrote:Can any help me please, i'm new to all this. I've just installed Garmin XT to my nokia N95 8gb and it works a treat. The only problem i have is that i don't have the Postcode search option................
You probably have the 'Major routes of Europe' map and not the 'detailed' map which contains postcodes & POI etc.
You may be better off buying / downloading the UK & Ireland Map, which will contain the UK postcodes.
