N85 voicemail number retention problems
1 replies · 5,738 views · Started 13 July 2009
I have previously posted on here that my N85 has singularly failed to remember my t-mobile voicemail number ever since I've owned the thing (from Dec 08), even with firmware updates.
What happens is if I enter it once, it then forgets it and I have to enter it everytime I press and hold down "1" for example. of course, easiest way is to create a contact for it.
Well, something intriguing happened last night.
My girfriend and I swapped SIMs and she's having my number and me hers. Inserting her SIM into my N85 has resulted in the N85 now remembering her voicemail number without me doing anything.
Anyone else with the initial problem tried changing the SIM and then going back again to see if it works?
F
well try to consult your voicemail service provider so it can gave you some little advice in how to fix your N85 voicemail retention problem...
_________________
ip pbx
