NSS Error, tried multiple installs nothing works (N96)
4 replies · 8,451 views · Started 13 July 2009
I'm stuck trying to get NSS working so I can debrand the new N96 I just got as a replacement as from my operator.
No matter how I set it up I get the "Error!" messages on the status bar with almost any transaction I did. I even tried installing XP clean as follows:
* Re-install XP
* Install XP SP3
* Install NSS with defaults
* Run
Result: Error
I read in a few places that the Nokia PC Suite has to be installed. I've tried downloading & installing that but it seems to make no difference at all.
I'm also confused about all the various driver options available: As i said, this time I used the default there are 3 others to choose from. What are they for, and might they work if the others fail?
Thanks,
Sal
Can you tell me which versions of the following products you used?
* Ovi Suite
* NSS
* Windows (did you use Service Packs?)
Did you have too install anything else?
salimfadhley wrote:Can you tell me which versions of the following products you used?
* Ovi Suite
* NSS
ovi suite : 1.1.374
nss : 1.0.38.15
vista ultimate 32bit sp2
ive also debranded using xp pro 32bit sp3
