How to convert Videos to highest quality in N97?
6 replies · 18,259 views · Started 15 July 2009
Can someone share some methods that they transfer high quality videos into N97?
I tried some converters but quality is not that good...
Thanks.
Well I use ffmpeg on my ubuntu box to convert videos using the following command
ffmpeg -i "input.avi" -acodec libfaac -ab 128k -ac 2 -vcodec mpeg4 -b 1024k -s 640x360 "output.mp4"
Thanks, bacardiandwater. That was exactly what I needed for my n97 mini😊
For others wondering how to convert videos for nokia n97 mini in linux (i'm using linux mint isadora):
1. First, install ffmpeg and dependencies. See this tutorial (qt-faststart is not needed):
http://ubuntuforums.org//forum/thread/786095/
2.
The good thing is this command can be embedded in a shell script, and the whole process can be automated! All downloaded videos are unrar'ed, converted and uploaded to my phone every night at 3 AM 😊
i use XViDforPSP 5.0 for this, free converter, has option for 5800, same reso as the n97. converts great
I have used AVS on a Windows OS, it can be custom configured as desired and I have had very positive results with excellent quality.
I am going to try the Linux option though as I have Mint on a USB stick 😊
awaisuk wrote:How to convert Videos to highest quality in N97?
Thanks.
i know a step by step guide on how to convert video to Nokia N97 compatible format
http://www.bigasoft.com/articles/how-to-convert-video-to-nokia-with-nokia-video-converter.html
if you want highest quality in N97, then you need to pay attendion to step 4 in the above guide, just set higher resolution that your N97 can support.
hope it helps
