Ringtones
1 replies · 2,122 views · Started 15 July 2009
Was wondering how do I put ringtones on the phone and what format they need to be in.
Any mp3 file can be used as a ringtone. Probably .mid format midi files too.
Dunno about other formats. .wav is Probably supported.
Just transfer them over, browse to them in file manager. Open and then select Use Tone>Set as ringing tone
Alternatively, drop the file into the e:/Sound Files/Ringing Tones folder and then go settings>profiles>options>personalise>ringing tone and select from there...
D
