One of my most essential Web Runtime apps, for S60 5th Edition, is Device Info - mainly for showing free RAM, but it does have plenty of other uses. It has now been updated to v2.0, with extra readouts, including IMEI. Grab it here for the 5800, N97 and Samsung i8910 HD. (via Wampyre)
I've had version 2 on www.davecozens.com/n97 for ages 😉
It's very good!
installed on my i8910, and while the app itself works fine, the icon is nowhere to be seen in the menu, I had to access it through smartsearch!
the icon appears fine for me on my i8910, no problems. Its in the Applications menu
mCrem wrote:installed on my i8910, and while the app itself works fine, the icon is nowhere to be seen in the menu, I had to access it through smartsearch!
Now that you mention the new version did not show any icons for me neither on the N97.
I believe the cause might be that upgrading from previous version some files are overwritten, hence the icon are not shown.
On my 5800 it borrowed the name and icon of my previously deleted Acuweather widget. A few times of opening and closing and paging through the launcher eventually got the Icon (first) and then the proper name to show up. 🙄
