:con?
Not sure what the problem is but the phone will show the Nokia screen but that is it. It kinda hangs on the Nokia screen, then switches off and then starts again. It doesn't reach the handshake part of the boot up process.
Any ideas anyone?
Cheers
That worked, thank you. LOL @ Vulcan death grip 😃
I have another small issue now which I could do with a bit of help if possible....
I used to use the Ovi Sync but obviously since the hard reset, all of my settings have gone.
I can see all of my contacts etc online however I cannot find the settings for my handset anywhere. On initial registration you recieve a text with the settings, problem is that I can't seem to find any settings to add manually. Are there any anywhere?
Cheers guys
Did you make a backup ? Instruments > MemoryCard > Options > Make Backup . Restore from there .
Or a Backup on your Computer ? PC Suite ? Restore from there .
Was your Messaging > Options > Settings , set to memorycard , then the SMS could still be there .
Or maybe is there an Ovi helpdesk ?
😊 Regards jApi NL
