CodeWarrior Wireless Development Kit for Symbian Series 60
2 replies · 2,228 views · Started 05 March 2003
This is weird! I don't understand how this could work. It's a known fact that you cannot use Visual C++ with SE P800 UIQ SDK then how should it work vice versa? Because the class libraries in Series 60 SDK are compiled with Visual C++ then how can you compile and make your application work with CodeWarrior C++ compiler?
[quote="simeonbubblegum"]Because the class libraries in Series 60 SDK are compiled with Visual C++ then how can you compile and make your application work with CodeWarrior C++ compiler?[/quote]
That's because the kit include the Series 60 SDK built with CodeWarrior.
Series 60 SDK from Forum Nokia can be used only with M$ IDEs and not with CodeWarrior.
