Hey there, I'm having trouble connecting my Nokia N73 to my PC. I have been able to use it before in the past and successfully been able to view the phones contents using Nokia PC Suite. When I plug the phone in to my PC it gives me the options of PC Suite, Mass Memory etc.. I select PC Suite and nothing happens :icon13: I have tried using different USB port on my PC and it has still not worked.
Anyone got any ideas to how I can get my PC to recognise the phone as a plugged in device?
Hi - i have the same problem with my N73 from time to time, it seems that the "pop port" (the connection on the bottom of the phone) is worn, i have to slightly move the connection cable when its in the phone, until the USB connection symbol shows on my phone screen, then it connects.
I tried a new data cable, but still have the problem now and then.
Regards
Markkyboy
Yeah seem to have the problem. Finally managed to get it connected after a bit of messing around with the data cable. Thanks for the reply (Y)
