SymbianScientist RSS widget, loads the latest posts in the apps window, also if you select the READ MORE option under each new feed it will take you to that post in your browser.
Download .. http://www.speedyshare.com/281785235.html
Looking at the screenshot, it seems they did the same thing as I did with my Big Brother 10 widget: based it on the RSS Feed coding example in Dreamweaver.
All you really have to do is put in the URL of your RSS Feed and compile it.
zxon wrote:Looking at the screenshot, it seems they did the same thing as I did with my Big Brother 10 widget: based it on the RSS Feed coding example in Dreamweaver.All you really have to do is put in the URL of your RSS Feed and compile it.
yes thats all i did, easy eh lol
