I HATE SAMSUNG! Cant uninstall PC Studio 7
19 replies · 63,452 views · Started 20 July 2009
I have read on the forums here that a software update is available for the i8910. So i plug my phone in and try again on PC Studio 7 to update my phones software.
No suprises, it still doesnt recognise my phone.
So i go to the Samsung Mobile website and Im happy to see that there is a new version of the PC Studio 7 - 7.2.24.9
I currently have 7.2.20.9
I think, maybe that this might work. So I download the new version and try to install it, and it breaks off and tells me I need to uninstall previous versions first. Fair enough, I go to my contraol panel, add remove programs, and there is no option to uninstall PC Studio 7 (7.2.24.9)! It just tries to reinstall itself!
So my phone is full of bugs, and a firmware upgrade is now available, however I cant get it because they havent even thought through the software to allow people to access updates!
I cant believe I bought this piece of crap phone, and then kept it past the 14 days in the belief that they may fix it.
Impressed by the hardware, but software support is shocking. This phone should not have been released, its not ready!
Any suggestions/help/advice/person who want to buy my handset - please respond!
Hi - you're right! I agree! I too found the (let's call it...) v24 of PC studio - when I first had the i8910 it was v20. Mine deinstalled/installed ok though (XP).
Yes, up to one week ago, v24 still did not see my xxIE2 Orange handset 'not recognised'.
I went for the debrand aobut a week ago... Once the xxIF7 italian firmware was on, guess what, the same PC studio v24 software just 'saw' my handset straight off (!!!), no messing about, and just went & downloaded and installed the italian xxIG2 update, no sweat!
It is Orange/Samsung in the UK which have released this handset 2-3 months too early with lots of broken software. I hereby award you their highest 'early adopter' medal! *friendly grin*
My handset is so much more stable, I recommend the debrand+xxIG2 updating. Look at my other post today on 'should I debrand'
For me with XP (i would only do it via XP !!!), the it was a painless process & totally transformed my i8910 experience this week.
Up to you, though... always that tiny risk... but, I tried it & it went ok.
Good luck!
I had the same experience. The uninstall does not work, which is a bloody shame for such a big multinational company. I solved it by resetting my system (winxp) to an earlier resetpoint. You could also remove the software by deleting it manually. But then you must also manually remove all the occurrences in the registry, which is a bit tricky, especially if you also have other samsung devices in your computer. Anyway if you decide to go that way, it's at your own risk and don't forget to backup your registry first!
The updater of the new version (24) did scan my phone for the need to update and used to return the (faulty) message "The mobile device is not supported by the updater". After I installed the 'intermediate 'dutch' update' (see this thread) the updater functions as you should expect. It now reports: "Updating is not necessary. The software is completely up to date." (translation by me 😊
e-
masonstorm wrote:Whats the easiest way to manually uninstall the program given that I'm on my work Vista laptop?
If you didn't install a lot of other software since you installed the old PC Studio version, I'd suggest to use the System Recovery tool. But even then you should backup your user data first on an external harddisk or usb stick or whatever. Not that System Recovery removes the user data, but you can't take the risk. There's always a small risk something goes wrong, although this proces is fairly safe.
A real manual uninstall would require manual deletion of the program files - typically in C:\Program Files\Samsung PLUS all the registry entries installed by the installer. This is the tricky part. You could search the registry for all occurences of 'samsung' and remove all those keys and values, but then you certainly must know what you are doing. If this is unfamiliar ground for you, I would strongly advice not to go that way.
Anyway, these advices are given without any warranty 😉
good luck
e-
FIRST CREATE A SYSTEM RESTORE POINT BEFORE ANY OF THIS, I take no responsibility for anything going wrong:
Try removing some of the individual components first so you at least get some of it off cleanly. They are called: "PC Connectivity Suite" "Samsung PC Studio 7", "SamsungConnectivityCableDriver" and "Windows Driver Package - Nokia".
Try searching for the main registry settings for the software, "HKEY_LOCAL_MACHINE\SOFTWARE\Samsung" and the remaining uninstall strings under "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall", export each and then delete them. That may fool the new installer that the old version is no longer present.
I had/have the exact same problem. Luckily I own 2 pcs so I installed it on the other one. However, after installing the new firmware I can tell you that the phone still sucks. I haven't noticed any improvements at all. And the browser is at a new level of unstableness(is that a word?). After rafe did the story on browser speed and I did some testing on my own I can tell you that my i8910 is SLOW. Slower than my n95 8gb sometimes. So yeah, I hate samsung to.
Tenkom wrote:I had/have the exact same problem. Luckily I own 2 pcs so I installed it on the other one. However, after installing the new firmware I can tell you that the phone still sucks. I haven't noticed any improvements at all. And the browser is at a new level of unstableness(is that a word?). After rafe did the story on browser speed and I did some testing on my own I can tell you that my i8910 is SLOW. Slower than my n95 8gb sometimes. So yeah, I hate samsung to.
What version firmware did you get updated to?
I had the same issue while trying to uninstall the old version. Then I used the installer from the original CD. Going through the options it will give you a chance to remove the old version, and guess what..........it worked
I've had a similar problem - what worked for me was the run the Nokia PC Suite Cleaner 7.1.1
You can find it on the Nokia site.
Once I ran this cleaner I could install the latest version of the Samsung PC Studio without any problems.....:icon14:
I've tried like everything, deleted all the registry entries with samsung, deleted all the files, everything.
And no success, the PC Studio still somehow finds out that the previous version is installed.
Frustrating.
Any help?
Have you tried to start the old setup routine you used for the installation? (the old one, not the new one) Then you should have an uninstall option.
That worked for me.
Thanks Alex, that worked for me, sort of 😊
I ran the installer from previous version. Although it didn't install anything, I got the remove option in the control panel.
After that I could install the new version.
The only catch is I have to connect the phone to a different USB port now.
Guess I deleted to many "samsung" entries in the registry.
BTW: The software updater is the same version and still doesn't recognize my phone. So new version of PC studio is not the problem solver for not being able to install firmware updates. Guess we just have to wait bit more.
Thanks,
Jure
I had the same problem not being able to uninstall the older version
but used Revo uninstaller (google it) and it did the job
it takes a system restore, uninstalls and picks bits out of the registry
sorted now
but really samsung ... removing your software shouldn't be like trying to pick out a veruca
Cant uninstall Samsung PC Studio 7
I have been going CRAZY with this for the last 2 days.
SOLUTION:
go to C:\WINDOWS\Installer
find the file with the date you first installed PC STUDIO.
Click and the uninstall or repair box comes up.
easy as that.
I did download the following which may or may not have helped.
But until i found the installer file NOTHING worked.
- Nokia_PC_Suite_Cleaner_7_1_1
- Revo Uninstaller
I found a good and fast solution.
Download the trail version of WINer tweak 3.
If you installed it you can delete the samsung PC studio 7.
Normally there are 2 files listed called "Samsung PC studio 7", try both of them, and one of them is the uninstall file of samsung PC studio 7.
After the uninstall you can install the new file of PC studio.
Grtz
I just got my samsung sgh g810 I picked up the installer disk put it in my
computer only after I had installed it I realised that I had installed my sisters
samsung software (which isn't a symbian) so i tried to install my symbian software
i says remove all other samsung software, fair enough.I went to control panel
add or remove programs and "removed" my sisters software. I went back to the
installer and it still gives me the same response. Please remove all other samsung software.
help
Is there another way except manually removing samsung files??
This doesn't help you...
but, from day one with the i8910, I built and have used a PC with all the latest XP patches, etc. on, just for the i8910. I've never run into any PC studio issues as a result, except one time I had to remove everything (including all registry entries by hand (my choice, but then I must have some kind of crazy streak)) in order to ensure the smooth reinstall of the latest PC studio software (which in itself is, I AGREE WITH EVERYONE HERE, the most incredible level of beta program, RC at best, released that I have ever used). I must obviously have always bought a relatively mature handset before the i8910. I have concluded that for the i8910 product, Samsung's standards dropped a long way. :frown:
