I want to synchronise my Palm TX with my SE G900.
The best software seems to be Xtndconnect pc 7, so I downloaded a trial and was able to synchronize outlook with the palm.
But when connecting with the G900 the sync fails.
I'm running a pc on windows XP SP3 with outlook 2003.
I already contacted Sybase support but so far without success.
I tried on another pc with Windows XP SP3 and outlook 2003 and there it works ok, also on a Vista pc with Outlook with 2003.
Hereafter the contents of the logfile.
Can anybody help me out?
Data Path: C:\Documents and Settings\deboopi\Application Data\XCPCSync.OEM\iAnywhere.101.101
50:19 rstDSSonyEricsson : SetConnectedDevice:TransDLLAPI:
50:19 rstDSSonyEricsson : UninitTranslator:TransDLLAPI:
50:19 DllExport UninitTranslator: No CancelCheckThread to delete
50:20 DllExport UninitTranslator: Uninit complete
50:20 CUI2Helper::SelectProfile: UpdateRegistryForSyncMLTrans()
51:13 CRSyncUtil::GetTranslator : Path 'C:\Program Files\Common Files\XCPCSync.OEM\iAnywhere.101.101\Translators\SonyEr;' added to environment variable while loading translator 'SonyEr'
51:13 Translator 'SonyEr' with version '1.0' loaded successfully from 'C:\Program Files\Common Files\XCPCSync.OEM\iAnywhere.101.101\Translators\SonyEr\rstSonyEr.dll'
51:13 Module Version: 9.9.9
51:13 CrstSonyApp::LoadTranslator : Loading translator DSSonyEricsson.dll
51:13 rstDSSonyEricsson : SetConnectedDevice:TransDLLAPI:
51:13 rstDSSonyEricsson : InitTranslatorEx:TransDLLAPI:
51:13 CRSyncUtil::GetTranslator : Translator successfully initialized for translator 'SonyEr'
51:13 CRSyncUtil::GetTranslator : Loaded, initialized and recorded translator 'SonyEr' successfully
51:13 rstDSSonyEricsson : GetMachineInfo:TransDLLAPI
51:13 CUI2Helper::SelectProfile: UpdateRegistryForSyncMLTrans()
51:13 CRSyncUtil::GetTranslator : Path 'C:\Program Files\Common Files\XCPCSync.OEM\iAnywhere.101.101\Translators\MSOl;' added to environment variable while loading translator 'MSOl
51:14 Translator 'MSOl' with version '1.2' loaded successfully from 'C:\Program Files\Common Files\XCPCSync.OEM\iAnywhere.101.101\Translators\MSOl\rstOl.dll'
51:14 Module Version: 7.0.10105
51:14 Enter MSOL : InitTranslatorEx
51:15 OlAccess::CDOVersionGreaterOrEqual CDO VERSION REPORTED BY OL: 1.21
51:18 CRSyncUtil::GetTranslator : Translator successfully initialized for translator 'MSOl'
51:18 CRSyncUtil::GetTranslator : Loaded, initialized and recorded translator 'MSOl' successfully
51:18 Enter CRSyncUtil::GetSyncStatus - Input : ContractId - 65538 , App1Id - 47 , App2Id - 32
51:18 rstDSSonyEricsson : GetTranslatorObject:TransDLLAPI:
51:18 ECSyncMLProtocol::ProcessSyncML Entrance - process to state 1
51:18 Enter IsTranferAborted
51:18 Exit IsTranferAborted
51:18 ECSyncMLProtocol::ProcessSyncML Loop (state) = NULL session
51:21 ECSyncMLProtocol::InitTransport SyncML Transport API version: 1 1
51:21 ECSyncMLProtocol::InitTransport STAPI version: 37.0.2037268841.1919248503
51:21 ECSyncMLProtocol::InitTransport WinObex version: 808529509.808529457.3014705.1919248503
51:21 ECSyncMLProtocol::InitTransport XCSyncML version: 3014705.3145777.49.1919248503
51:21 Enter IsTranferAborted
51:21 Exit IsTranferAborted
51:21 ECSyncMLProtocol::ProcessSyncML -- Preparse: Get a message...
51:21 ECSyncMLProtocol::ReceiveMessage receiving (state) = NULL session
51:21 ECSyncMLProtocol::ReceiveMessage : Read start
51:21 ECSyncMLProtocol::MakeTransportCallAndWait : Creating CTransportIOThread object.
52:22 TransportIOThreadProc :STAPI: SyncMLReadEx()... returned 1
52:22 ECSyncMLProtocol::MakeTransportCallAndWait : Thread is finished.
52:22 ECSyncMLProtocol::ReceiveMessage : Read complete!
52:22 ECSyncMLProtocol::ReceiveMessage : ERROR1: Read failed! 1
52:22 Enter CFieldMap::LoadFieldMapFromFile
52:22 Enter MSOL : GetTranslatorObject
52:22 Enter CDSTransSyncEngAPI::GetAppInfo:TransSEAPI: bChange=0, csSelection=, csSubSelection=, csDisplayName=, bReloadFields=0
52:22 CInternalTrans::LoadDeviceFields()
52:22 CInternalTrans::LoadDynFields: Using default Field Map: C:\Documents and Settings\deboopi\Application Data\XCPCSync.OEM\iAnywhere.101.101\Translators\DSSonyEricsson\DS_fiel dmap.xml
52:22 MapDynFieldsToDeviceFields: DTSTART
52:22 MapDynFieldToDeviceFields: dynField=DTSTART, nNumPositions=1
52:22 MapDynFieldsToDeviceFields: DTEND
52:22 MapDynFieldToDeviceFields: dynField=DTEND, nNumPositions=1
52:22 MapDynFieldsToDeviceFields: SUMMARY
52:22 MapDynFieldToDeviceFields: dynField=SUMMARY, nNumPositions=1
52:22 MapDynFieldsToDeviceFields: DESCRIPTION
52:22 MapDynFieldToDeviceFields: dynField=DESCRIPTION, nNumPositions=1
52:22 MapDynFieldsToDeviceFields: LOCATION
52:22 MapDynFieldToDeviceFields: dynField=LOCATION, nNumPositions=1
52:22 MapDynFieldsToDeviceFields: AALARM
52:22 MapDynFieldToDeviceFields: dynField=AALARM, nNumPositions=1
52:22 MapDynFieldsToDeviceFields: CATEGORIES
52:22 MapDynFieldToDeviceFields: dynField=CATEGORIES, nNumPositions=1
52:22 MapDynFieldsToDeviceFields: CLASS
52:22 MapDynFieldToDeviceFields: dynField=CLASS, nNumPositions=1
52:22 MapDynFieldsToDeviceFields: X-EPOCAGENDAENTRYTYPE
52:22 MapDynFieldToDeviceFields: dynField=X-EPOCAGENDAENTRYTYPE, nNumPositions=1
52:22 MapDynFieldsToDeviceFields: RRULE
52:22 MapDynFieldToDeviceFields: dynField=RRULE, nNumPositions=1
52:22 MapDynFieldsToDeviceFields: EXDATE
52:22 MapDynFieldToDeviceFields: dynField=EXDATE, nNumPositions=1
52:22 CFieldMap::MapSpecialFields: Adding StartDate
52:22 CFieldMap::MapSpecialFields: Adding StartTime
52:22 CFieldMap::MapSpecialFields: Adding EndDate
52:22 CFieldMap::MapSpecialFields: Adding EndTime
52:22 CFieldMap::MapSpecialFields: Adding AlarmDate
52:22 CFieldMap::MapSpecialFields: Adding AlarmTime
52:22 CFieldMap::MapSpecialFields: Adding AlarmFlag
52:22 CFieldMap::MapSpecialFields: Adding Classification
52:22 CFieldMap::MapSpecialFields: Adding Recurrence
52:22 CFieldMap::MapSpecialFields: Adding Custom19
52:22 CFieldMap::MapSpecialFields: Adding AllDayEvent
52:22 CFieldMap::MapSpecialFields: Adding Custom20
52:22 CDSTransSyncEngAPI::GetAppInfo : returning rsSuccess, m_csSelection=
52:22 ECSyncMLProtocol::ProcessSyncML Entrance - process to state 4
52:22 Enter IsTranferAborted
52:22 Exit IsTranferAborted
52:22 ECSyncMLProtocol::ProcessSyncML Loop (state) = NULL session
52:22 ECSyncMLProtocol::ProcessSyncML -- Preparse: not second pass - calling SendReplyToClient...
15:32 Enter CRSyncUtil::Close
15:32 Enter MSOL : UninitTranslator
