Begennir questions
6 replies · 2,295 views · Started 05 March 2003
1.) Is there a way to check the software version like the keys you put in on the T68i?
2.)Is there a camera lens protector or cover available/built in?(because I find that my finger keeps on accidently touching the lense ergo smudging the lense.
3.)How do I move all my phonebook from the T68i to the P800?
4.) When listening to MP3's does it autmatically stop when a call is coming in?
Thanks in advance guys! 😊
To check your software version, click view (upper portion of your screen on flip open mode), then select system information. For the camera lens protector, there is currently none. Maybe what you can do is make one yourself using some plastic if thats what you want. As for the fone book, i suggest that you copy it to your sim and from there trransfer it to your P800. And when listening to mp3, yes it does stop when an incoming call comes in
Thanks Christomas 😊 One prob though, my sim cant hold multi entries on a single name. Eg: Name with address,number,email etc.. So I cant move all the phonebook to the sim 😞
To move your complete Phonebook fro mthe t68i to the P800 there's a funktion on the T68 to send the complete Phonebook via Bluetooth or IR...
[quote="michis0806"]To move your complete Phonebook fro mthe t68i to the P800 there's a funktion on the T68 to send the complete Phonebook via Bluetooth or IR...[/quote]
Yes but the funny thing is when I do that the p800 just does nothing 😞 With bluetooth it sez do i want to rcv the file but when i click yes on the p800 the t68i keeps on saying sending then stops and when i look at the address book of the p800 nothings there 😞
[quote="Muzikfreakah"]1.) Is there a way to check the software version like the keys you put in on the T68i?
[/quote]
Well you check the software version of the phone from the main menu.
In the upper bar do as follows
Tap View
Tap System Information
Tap the right arrow
[/quote]
It will shutdown the mp3 and redirect the call to the foreground, the very unfortunate thing is it will not resume playing the MP3 after the phonecall, you have to start the MP3 by yourself again.
This is why I wish for someone to write/port a third party media player to the device so that this feature can be supported.
[quote="Anonymous"][quote="michis0806"]To move your complete Phonebook fro mthe t68i to the P800 there's a funktion on the T68 to send the complete Phonebook via Bluetooth or IR...[/quote]
Yes but the funny thing is when I do that the p800 just does nothing 😞 With bluetooth it sez do i want to rcv the file but when i click yes on the p800 the t68i keeps on saying sending then stops and when i look at the address book of the p800 nothings there 😞[/quote]
I think the Phonebook items are in "Messages" --> Beamed. I think the files are there! Just click on them and "install" them.
