Hi
I use my N97 only for personal use, so, is there any point in having MfE installed?
If there isn't should I uninstall it - will it save memory?
Steve
Hi
Steve
By default, its not installed - only when you use Nokia Messenger and create an account that uses Exchange that it will go and download it and install. So no, it does not use memory until you actually use it.
Thanks for your help. I did download and install Nokia Messenger, also logged in to my Nokia account. I presume this has activated it - do you know how to uninstall it/ whether to uninstall it?
Cheers
Steve
