Does anyone know of such a thing? I seem to remember seeing mention of one but I can't find it now.
I've seen the Iphone app working which enables you to set your Sky Plus - It would be great if we could get something similar! 😊
There's Vizimo which IIRC is a java app. Works ok on the N97, and lets you put programme times in your calendar.
There certainly was a Sky app for the N95 but I don't know about the N97. Check out Sky and see.
[EDIT] I've just checked and sadly the N97 isn't listed as a compatible device yet. However, since the N95 (and, according to pictures on Sky's website, the N96 too) is supported then it's only a matter of time before the N97 is supported too.
[EDIT #2] Found it! Try here.
Brilliant! I've been waiting for that! Thanks.
Cool thanks.
I wonder if they will add Virgin Media support at some point. I'd have thought that it would be easier to do than Sky because virgin has propper two way data.
Give Snaptu a try too: http://www.snaptu.com/
TV guide along with a load of other info toys. Works nice on the N97.
I can feel a widget coming on...
Has anyone else managed to get their Vizimo account working? I simply can not sign into the service. I know I'm using the right password as I got the site to email it to me.
I've tried twice now and just no luck - odd. :con?
BanziBarn wrote:Has anyone else managed to get their Vizimo account working? I simply can not sign into the service. I know I'm using the right password as I got the site to email it to me.I've tried twice now and just no luck - odd. :con?
Its not just you I'm having the same problem :icon13:
zxon wrote:There's Vizimo which IIRC is a java app. Works ok on the N97, and lets you put programme times in your calendar.There certainly was a Sky app for the N95 but I don't know about the N97. Check out Sky and see.
You superstar! Been waiting for this too. 😊
Blimy! No problem everyone!
I'd forgotten about the Sky+ app to be honest, until this thread was started. Only took 10 minutes to hunt it down 😃
