Calendar Entry issue on N95?
1 replies · 2,539 views · Started 27 July 2009
Can anyone help? I want to save my calendar entries to my storage card, and not, as present, to the phone memory, as I have too mant calendar entries and it eats all the phone memory.
Probably an easy fix but I can't find a way to configure the settings.
I have a classic N95, if that helps!
Many thanks!
It's a pity , but Calendar cannot be set to MemoryCard , not even a backup is possible on MC (Symbian S60) . It was possible with the older Phones , like 9300 , 9500 (Symbian S80) .
I backup my Calendar on a second Phone . Otherwise you need a PC (e.g. Nokia PC Suite) , or online backup (e.g. OVI , Google or else) .
BTW : hard reset , firmware update are deleting the complete Calendar . So allways make a Backup to restore .
😊 Regards jApi NL
