S.O.S - Nokia Map Loader 3.0.24.0 not transferring map data to Nokia N97
2 replies · 6,772 views · Started 27 July 2009
When I download the maps for Europe using Nokia Map Loader and attempt to transfer the data to the phone, only the voice data copies across. The map data does not copy.
I have Ovi Maps v3.01 09wk26 b02 installed on the Nokia N97.
Any ideas? Is there a manual method?
You can copy the map files into the 'cities' folder. I think there is also a config file you need to copy. But you'd need to get hold of the map files first (maybe if anyone can upload them).
PaddyMcJustin wrote:When I download the maps for Europe using Nokia Map Loader and attempt to transfer the data to the phone, only the voice data copies across. The map data does not copy.
The solution.
1. Delete 'qf' file and 'cities' folder from mass memory
2. Start maps
3. Exit maps
4. Connect N97 to PC
5. Fire up Map Loader and proceed as normal
