I've got a N85 since 2 days. When I connect usb cable during music player active, it freeze with a message "usb connecting".
Does anyone got an idea ? I've already made several querys in forums, but I haven't find any answer...
Is it possible to listen music during usb charging ?
I've called the Nokia Care Center.
Answer is :
" You can't use any apps while connecting usb because it's not build for that. You have to choose between charging or transfering data , but you can't do data transfer or charging when you use an application.
So, you have to plug the wall charger and then you can use the music player"
Ok, but if I want to use my n85 as a mp3 player and a mass storage what can I do ? My old Sagem 401 could do that !!
