MonarchX wrote:1. First of all - how do you create shortcuts to go on home screen? I want a shortcut for custom application - Garmin Mobile XT. 2. Is there a better MP3 player than default one for free? What about AVI/MPG player?
3. How do I adjust N97 camera shutter speed? I end up having blurry images because the shutter speed they set requires you to hold camera 100% still!
4. Any must-have applications? Any good sites to look for freeware and paid but good apps?
5. Can I somehow make N97 use USB connection to browse the internet through my PC?
6. Is it OK to uninstall default apps? Some, like API Bridges, sound like system files that have dependencies... should I just leave default apps alone for best stability? I don't have problems with the unit or any apps for now.
7. What about games? Does N97 have N-Gage built-in or is it emulating N-Gage? Any good sites to look for N97-compatible games, reviews, and such?
1 - From the home screen, press options, and choose edit content. From tehre you can tap on any of the widgets to remove them, or to add content, so from there you can add a shortcut bar , or two if you want to.
All shortcut bars allow for up to four applications, so you should be able to get a shortcut to Garmin. ( Which version of Garmin have you got BTW ? Can't get mine to work properly )
2 - Probably is, but haven't really looked for one, happy with the one that came with the phone.
3 - No idea, sorry.
4 - Check out Dave's N97 Freeware site
5 - Have you tried Joikuspot? Turns your phone into a wifi hotspot and you can then wirelessly connect your laptop to the phone and surf away.
6 - Not sure, so won't attempt this question.
7 - There is an NGage update now for the phone, so go to Applications, Software Update, choose refresh and N Gage should show up on the list, where you can download it over the air. Once this is done, you can then connect to the NGAge site and buy games / downlaod demo's.
Good Luck.
