...If I connect my E71 to a PC with the USB cable, it appears to corrupt my music libary (ie if I turn on the player, it spends 10 mins rebuilding the libary) This doesnt happen if I use bluetooth..
Dose anyone else have this problem? Any known fixes?
Yes same for me.
Ive stopped using the usb altogether as it happens every time and removes the album artwork as well so all in all an annoying little problem!
dave9999 wrote:...If I connect my E71 to a PC with the USB cable, it appears to corrupt my music libary (ie if I turn on the player, it spends 10 mins rebuilding the libary) This doesnt happen if I use bluetooth..Dose anyone else have this problem? Any known fixes?
Just curious : are you using PC Suite or MassTransfer ? Or does it happen equally ? There must be some software messing around in the library trying to "reorganize" things . Setting maybe ....
😊 Regards jApi NL
