Firstly, How can I have two message widgets on the home page, so i can see both my E-mail and text messages?
Secondly, I tried to use the Nokia maps and do a post code search. However, it would not let me put in numbers for the post code, only letters/Symbols?
You probably inadvertently hit the "Sym" key next to the space bar which changes the keyboard text input mode between numbers and qwerty. As far as I know there is only email and no separate widget for reading text/sms messages but I haven't looked into this
Cadey wrote:Firstly, How can I have two message widgets on the home page, so i can see both my E-mail and text messages?Secondly, I tried to use the Nokia maps and do a post code search. However, it would not let me put in numbers for the post code, only letters/Symbols?
Also, for numbers instead of letters, you hold the number button until the number appears. If you just tap it, you get letters.
Later.... 😎
hdbueller wrote:Also, for numbers instead of letters, you hold the number button until the number appears. If you just tap it, you get letters.
Later.... 😎
that just auto repeats the letters on my N97 - rather than selecting the shifted value - like every other nokia keypad - e71 included.
